TwinTurbo.NET: Nissan 300ZX forum - remove the inner sleeve, sawzall/air chisel
spyhunterTT(nj)
on August 07, 2007 at 8:58 AM
ES Differential bushings replacement... problem
posted by Dark Diver
on August 07, 2007 at 05:26 AM
If the subframe is off the car, You can use a large c clamp and some wood blocks to press in the new rubber.
Alex
Dark Diver
05:26:11 08/07/07
Are these "metal tube" what you name "sleeves" in many posts
Dark Diver
07:13:40 08/07/07
Yes, you need to remove the sleeve.
300zx90 (CO)
08:25:23 08/07/07
Thank you for posting that!
bstyleZ
09:21:17 08/08/07
remove the inner sleeve, sawzall/air chisel -
spyhunterTT(nj)
08:58:42 08/07/07
OK, thanks for this confirmation.
Dark Diver
13:32:07 08/07/07
did you remove all the sleeves or did you leave the very
ZonaZ
13:48:26 08/07/07
He's changing diff bushings, not subframe bushings (n/m)
300zx90 (CO)
13:54:18 08/07/07
ok, got subframe bushings on the brain...I want to take
ZonaZ
14:13:48 08/07/07
